Midpipe Change question
  • Thread starter Thread starter bullitt_2620
  • Start date Start date Jun 4, 2007
bullitt_2620
91
San Diego, cali.
Jun 4, 2007
  • Jun 4, 2007
I have to change back to my stock midpipe so I can pass cali smog. What tools do I need? I think it's a couple of socket extenders and elbows or something...
03redgtstang
Banned
Apr 24, 2007
105
  • Jun 4, 2007
at the manifold left side you wont need any swivel, just extensions. Right side you will need the swivel, and 2 extensions to reach, i believe i used 15 mm socket with a 1/2 drive ratchet and 2 extensions. You will need deep well to get clearance over the bolt. Right side is a biaatch.
and to tighten down the o2's youll need the wrench (not sure size) or 02 socket with ratchet
D
Dragstr05
643
Stafford VA
Jun 4, 2007
  • Jun 4, 2007
The longer the extension the better for the most part. Nuts/Bolts are 1/2" or 15mm(I think), but I know for sure 1/2" will work, although I usually use a metric size. Swivels are good, and will work for most of them, but one nut on the right side is VERY difficult to get with a swivel...universal joints work better on that one if you can loosen them by hand, as you cant use an impact with a universal joint.
O2's are 7/8". I like to use a very long flat head screw driver for disconnecting the O2 harness connectoer.
F
flyboy86
94
Vance AFB, Enid OK
Jun 4, 2007
  • Jun 4, 2007
I remember my O2s being 22mm, but I could be smokin crack.
03redgtstang
Banned
Apr 24, 2007
105
  • Jun 4, 2007
the bolt that dragstr says is really hard to get at is the lower one. Its becuase if you go too deep well with it it rubs up against the exhaust pipe and wont go on the bolt. you gotta really get the right size socket not to short not too long. It is a PITA. You shouldn't need any pb blaster or anything depending on how long youve had the mid on.
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Greetings from Duluth, GA
  • DuluthFoxbody
  • Oct 25, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 26, 2026
gkomo
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
