MIL WON'T WORK!!!
  • Thread starter Thread starter MArkT
  • Start date Start date Jan 18, 2013
M
MArkT
  • Jan 18, 2013
can anyone please point me to a thread or give me some info on MIL not working ie. test procedure , instrument panel teardown , or any other probable cause and/or solution ..thank you ...
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 18, 2013
  • Jan 18, 2013
How about the vehicle information first.
M
MArkT
  • Jan 18, 2013
oops my bad 1990 lx 5.0
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 18, 2013
  • Jan 18, 2013
Turn the ignition switch to Run, but do not crank the engine. All the indicator lights should illuminate.
If you are looking to see what codes the computer has stored, here's how...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
M
MArkT
  • Jan 18, 2013
What steps do I take if the light does not come on as it always had when in KOEO . Is it just a bulb? The other lamps illuminate as usual but the mil just doesn't light up at all . This is a problem when trying to pass emissions ( instant fail) . car runs great though
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Jan 19, 2013
  • Jan 19, 2013
It's just a bulb back there. Given the car is over 20 years old, it's probably burned out.
Does the check engine light turn on when you turn thhe key to ON but don't start engine? If not, first thing I'd do is take the gauge cluster out and replace the bulb.
Removing the cluster is not that hard.
M
MArkT
  • Jan 21, 2013
done thanks I don't know why I thought it had to be more complicated .. Thank u
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Jan 22, 2013
  • Jan 22, 2013
NP.
BTW, for some reason when i saw the notification on this thread, my first thought was MIL = Mother-in-law.
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
