Misfire Issue
  • Thread starter Thread starter hatchback88
  • Start date Start date Sep 3, 2012
hatchback88
24
  • Sep 3, 2012
I've got a 89 fox that ran great in September 2011. It was down for a year do to a torque box issue but I have now got it back together and running again it hasn't been fired up sense Feb of this year. So I pulled my equal lengths off and put long tubes on. Fired it up and it ran great. Next day replaced the plugs and started it up and I had a miss on accel possibly at idle but can't really tell due to the cam. Found the msd wires and cap cracked and corroded replaced all of it. Fired up today no miss on accel ran great until it was up to operating temperature now I've got a bad shake/miss on deceleration. Not sure if its something as simple as plug gap or what but before these plugs l had e3 s in it and no problems let me know what you think
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2012
  • Sep 4, 2012
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
gearheadboy
1,425
177
84
Greencastle Pa
Sep 5, 2012
  • Sep 5, 2012
I've had that issue after I dropped a plug on the floor and then installed it. Sometimes a crack in the plug will make them miss when warm.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
