  • SN95 4.6L Mustang Tech
Misfires
  • Thread starter Thread starter Redfire03GT
  • Start date Start date Nov 4, 2004
Redfire03GT
395
Newark, CA.
Nov 4, 2004
  • Nov 4, 2004
Ok, I've taken my car to Ford 3 times now. I have a pesky consistant misfire. Each time, they change the plugs thinking it'll fix it. I put in Autolite 764's at first, still misfired, then I tried APP764's, double platinums, still misfired. Then I tried Motorcraft platinums, still misfired. Ford has changed the plugs themselves 3 times and it still misfires. It seems to be eluding everyone who works on it.
The plugs were gapped properly. The timing is at stock. The coil packs are fine, according to Ford. None of the wiring is shot, once again, according to Ford.
The misfires only happen under heavy load/high rpms or sustained rpm's. Under very casual conditions, the car doesn't act up. But once that misfire code sets off, the car immediately becomes gutless and remains so even after the service engine light is off. The only "cure" is to reset the computer. Then, for a brief while, it's back to it's peppy self.
Ford has my car yet again, today. If the problem still isn't solved, what should I try next? I've been looking into getting a plasma booster purely for the sake of it's supposed ability to cure misfires. But, i feel that even that is merely a band-aid. I'd like to actually solve the problem not just simply make it go away by drowning it out.
Thanks for any info.
allutz
170
southeast pa
Nov 4, 2004
  • Nov 4, 2004
what codes are coming up???? is it random cylinder misfire(300) or a specific cylinder???(301-308)
chinostang
40
Sac
Nov 4, 2004
  • Nov 4, 2004
Does your car have trac control? My old 99 gt had a faulty sensor or something that made the trac control come on which does some cooky misfire type of thing to it. Just one among many reasons why it was a lemon.
Redfire03GT
395
Newark, CA.
Nov 4, 2004
  • Nov 4, 2004
Both.
Cylinders 3/4 are pretty consistant as far as showing up with a misfire and I'm getting the random misfire code.
I've spoken to Ford about that several times and they insisted the coil packs are fine and it was the spark plugs at fault. Even the ones they had replaced.
After speaking with them again today, they're going to replace all my coil packs and plugs once again in the hopes that it'll finally solve the problem.
ChaosStarter
1,637
Metuchen, NJ
Nov 4, 2004
  • Nov 4, 2004
check over all of your plug wires. look for white marks on the wires. if the wires were even close to metal, the spark will try to get to ground (least resistance path) and it'll go right through that rubber.
The white marks are ozone forming on the wires. if you see some marks (double check cyls 3/4), change your wires, and get them away from metal.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 4, 2004
  • Nov 4, 2004
no wires on his ride, 99+ have packs
Go HoTO!
602
Mountaintop, PA
Nov 4, 2004
  • Nov 4, 2004
I saw your post at MD and responded. Check out my comments. It the C&L MAF that is causing the problem!!!!! Take it off and put the stock MAF back on. Same thing happened to me in April. The C&L MAF was causing my car to run too lean and when the weather warmed up, BINGO, missfires. I took it off, and problem was solved....for good.
J
Joeycash718
Brooklyn
Jun 3, 2007
  • Jun 3, 2007
im having missfires myself, i just added a cold air kit and a new tps. now my car is so fuct up its not even funny. it sounds like a popcorn maker coming down the street. 2 different mechanics cant figure the problem out
Bluffing024
Somewhere
Jun 3, 2007
  • Jun 3, 2007
Why bring a 3 year old thread back?
J
Joeycash718
Brooklyn
Jun 4, 2007
#10
  • Jun 4, 2007
  • #10
i didnt even realize the date
geoffsgt
176
Baton Rouge, LA
Jun 4, 2007
#11
  • Jun 4, 2007
  • #11
This is what happens when people constantly get bitched at to do searches.
Bluffing024
Somewhere
Jun 4, 2007
#12
  • Jun 4, 2007
  • #12
Well, I guess this shows at least he did search...
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 5, 2007
#13
  • Jun 5, 2007
  • #13
You are getting detonation. 1st step would be to try a higher octane gasoline or at least run a major brand, if you are not already, and see if that solves it.
Bluffing024
Somewhere
Jun 5, 2007
#14
  • Jun 5, 2007
  • #14
Thats what it sounds like he is describing, but it may be another noise if he has had it to two different mechanics and they couldn't tell it might not be detonation. But definitely get the highest grade of gas you can to be safe and see if it goes away.
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
