More T-5 Swap problems
  • Thread starter Thread starter spyder2455
  • Start date Start date Jul 10, 2004
spyder2455
37
  • Jul 10, 2004
Now that i have to use a starter off of a 94 mustang, how do i properly wire it from the solonoid to make the starter engage and spin??? Do i have to add a wire from somewhere on the solonoid to connect to the starter?? Also when i turn the key, the starter does not get any power. I have one wire hooked up to the clutch pedal which i assumed was the neutral safety switch. Are there any other wires i might be missing that would cause this problem? Please help!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 10, 2004
  • Jul 10, 2004
Do a search on mini starter & you will find what you need.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
