morning sickness!!
  • Thread starter Thread starter boxcarracer89
  • Start date Start date Mar 13, 2011
boxcarracer89
153
I live in Roswell NM
Mar 13, 2011
  • Mar 13, 2011
I have a 92 ford mustang w edelbrock aluminum heads and gt-40 intake, headers and exhaust. In the morning I go out to start the car and i never wants to turn on for the past 3 or 4 days. I have been doing various things to it to get it to turn on, I changed the spark plugs one day, the next day was the spark plug wires, and so forth to get it going in the morning. When I get it to turn on, it runs great all day! It turns on and off without a problem!! Then I go to sleep and in the morning try to turn it on and it wont start for me. So any advice would be greatly appreciated!!
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Mar 13, 2011
  • Mar 13, 2011
I'd check all your battery cables and grounds.
Along with seeing if your battery is holding a charge properly.
If that stuff is fine, i'd check to see if you have a power drain while the car sits.
Culprits are the hatch light and the glove compartment light.
boxcarracer89
153
Mar 13, 2011
  • Mar 13, 2011
it cranks fine, the battery is charged and is anot being drained at all!
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Mar 13, 2011
  • Mar 13, 2011
You said in your first post that it doesn't want to turn over.
Turn over and cranks are pretty much the same thing.
boxcarracer89
153
Mar 13, 2011
  • Mar 13, 2011
sorry about that, but it wont turn on. it wants to stay on, then dies out immediatly.
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Mar 13, 2011
  • Mar 13, 2011
What exactly do you do to finally get it started and stay running?
boxcarracer89
153
Mar 13, 2011
  • Mar 13, 2011
One time I just cleaned the spark plugs, it started right up, another time i changed the spark plug wires and i had to crank it a few times but it turned on eventually. And today I tried to turn it on in the morning but it didnt want to, i did some body work to it and like a few hours later it turned right on!?
beyondspexj
265
Las Vegas
Mar 13, 2011
  • Mar 13, 2011
fuel pump relay?
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Mar 13, 2011
  • Mar 13, 2011
Next time it happens, print out jrickers cranks but no start checklist, and start checking them out.
There is a possibility beyond is right, when you turn the key to the on position listen for the fuel pump to prime.
boxcarracer89
153
Mar 13, 2011
#10
  • Mar 13, 2011
  • #10
ok I will do that, and Fuel pump is priming, smells like gas when it wont start also! Something to do with spark??
beyondspexj
265
Las Vegas
Mar 14, 2011
#11
  • Mar 14, 2011
  • #11
x2 on the checklist.
this was my issue last year. I replaced both my fuel pump and the relay at the same time though.
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Mar 14, 2011
#12
  • Mar 14, 2011
  • #12
Try starting it with the mass air meter unplugged.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 14, 2011
#13
  • Mar 14, 2011
  • #13
I had intermittent problems like this before. There is a plastic sensor on the distributor I replaced and it took care of the problem. I forget what it's called.
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Mar 14, 2011
#14
  • Mar 14, 2011
  • #14
You probably replaced the ignition module or TFI.
That could always be the problem, but most of the time it's heat that keeps it from working, so a cold car would be more likely to start.
There is also the pip sensor, jricker has suggested in the past that the pip may throw a code if it's bad, so i'd run the codes.
boxcarracer89
153
Mar 14, 2011
#15
  • Mar 14, 2011
  • #15
Thanks for all the input!!! Ill keep you guys updated!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 14, 2011
#16
  • Mar 14, 2011
  • #16
As suggested...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 16-Jan-2011 to clarify testing the EEC relay in paragraph 1E .
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
boxcarracer89
153
Mar 14, 2011
#17
  • Mar 14, 2011
  • #17
Thanks 4 the info!!
4rdnut
188
#18
  • Mar 15, 2011
  • #18
I would think it's magnetic interference from the ufo floating overhead there in roswell.
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
