Moroso rear drag springs: which sides does each go on???
The shorter (stiffer) spring goes on the passssenger side. As for ride height, my car sits perfect with the moroso springs in the rear. My 255/50/16 tires fill the wheel wells very nicely. The springs are just very sensitive to unlevel ground. So if I park on uneven ground, one side will be very low while the other is very high. i don't mind it though. You'll like the springs.
-scott
If they still have the alumium tags on them, they are marked "R" and "L". I am pretty sure the shorter one goes on the passenger side. Mash on each one, the shorter one should feel stiffer. Your car will be really high in the rear when you set it down. After you have driven a few miles on them it will settle alot, so dont panic like I did. Expect about stock ride height out of them.
