motor mounts
  • Thread starter Thread starter NFGTragedy
  • Start date Start date Apr 14, 2005
N
NFGTragedy
155
Rochester, NY
Apr 14, 2005
  • Apr 14, 2005
any ideas on the best way to change out motor mounts without pulling motor? I just got my motor in and ofcourse now they break... POS... i really don't want to pull it all back out but will if it has to be. Please bring me good news.
bgjohnson
963
johnston,iowa
Apr 14, 2005
  • Apr 14, 2005
that's the way i did mine, just put a block of wood under the oil pan, unbolt, jack up, unbolt it from the body. install new ones and your done. then again they said you can't do your oil pan gasket without lifting up the engine and i did.
Jason 302
685
71
68
Newark, Ohio
Apr 14, 2005
  • Apr 14, 2005
Yea, all you have to do is lift the motor high enough so the studs on the motor mounts can clear the K-member. I would probably loosen the block bolts before lifting the motor, might make it easier so the motor aint rocking around everywhere when your trying to pry on them. Pretty straight forward.
HISSIN50
34
129
Apr 14, 2005
  • Apr 14, 2005
if you have the stock fan, it is best to loosen the shroud so you can jack the motor higher (w/o the fan blade hitting the top of the shroud).
it can take some finagling on the pass side to get one of the mount bolts out (i disconnected the battery and the starter cable at the starter. then i was able to get the rear bolt in and out).
also note that some parts store mounts dont have the same bolt shank size as the old ones (meaning fasteners dont fit).
if using oem replacements, i would use the captured mounts from a vert (or a 93, as the captured vert mount became standard by 93). Jrichker has a post about doing them, with some specs, IIRC.
good luck.
J
jerry beach
2,671
Ocala,FL
Apr 14, 2005
  • Apr 14, 2005
You can also place some small blocks of wood between the engine and K-member in case the jack fails. Better to smash those than your fingers.
N
NFGTragedy
155
Rochester, NY
Apr 15, 2005
  • Apr 15, 2005
would i have to unbolt my exhaust like hpipe from headers or it should be alright?
HISSIN50
34
129
Apr 15, 2005
  • Apr 15, 2005
i did not have to on my 88 GT vert.
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
