  • SVT Tech Forum
Motor rough then stalled
  • Thread starter Thread starter silverback14
  • Start date Start date Dec 8, 2008
silverback14
West GA. I-20
Dec 8, 2008
  • Dec 8, 2008
I have an 04 cobra with a 2.90 pulley that I ran hard yesterday at an all 3rd gear track event, on my third 15 min session the car started cutting out and stalling. All gauges were normal, after sitting 30 min, it started and idled normal. On my way home 10 minutes later it coughed a few times and stalled. After 5+ min it would start and run OK for 15 min and then do the same thing with the check engine light coming on now. Finally made it home and read codes PO234 Super Charger, PO190 Fuel Rail Pressure. Any ideas? Will be going to the shop soon.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 9, 2008
  • Dec 9, 2008
Those codes don't sound good. Were using a Snap-On scanner? Mine gives me those PO codes and everytime I've changed what it said, my problem was gone. That scanner is the best. Sounds like the the supercharger may have gotten overheated. Repeated 3rd gear pulls can't be the best thing for those. Once you figure out the problem, I recommend buying a heavy duty intercool from Atco, or Fluidyne. I had a custom one made for my Lightning 2 years ago and that blower never suffered from heat after that.
silverback14
West GA. I-20
Dec 9, 2008
  • Dec 9, 2008
To SVT32
Thanks for your imput. I'm going to my mechanic who has Snap-On stuff and let him read codes, I used my Diablo. I already have a double pass HC and larger coolant tank. Did you mean it gave me false codes? Do you think a sensor is gone?
silverback14
West GA. I-20
Dec 11, 2008
  • Dec 11, 2008
Just found out from my mechanic that it was the fuel rail pressure sensor; this seems to be fairly common. I'm going to add a Kenne Bell disc as well and hope this solves it.
03SONIC
  • Dec 12, 2008
Welcome to making some power and shifting hard with a return less fuel system. Pumps on, pump off, this puts major stress on the FPRS because the FPRS see's these dips and tells the pcm to kick pumps on when rail pressure is low. You can work some of this out in the fuel tables of the time but you will never get rid of all of it, replace the FPRS, change the oil and filter as when they go bad fuel gets into your oil. You can run the disk although we do not like them, if anything do what I posted and have your tune checked.
silverback14
West GA. I-20
Dec 15, 2008
  • Dec 15, 2008
03 Sonic,
Thanks for the reply, have done all but the tune check, will do.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • SVT Tech Forum
