I went to Wal Mart today and noticied that they sell Motorcraft 5w20 Synthetic Blend motor oil. Has anyone used it or uses it? Is pure synthetic available in 5w20 or just synthetiv blend? What does Ford actually use?
Ford's original equipment oil filter is Motorcraft so the oil might be as well.JOSTANG75 said:I went to Wal Mart today and noticied that they sell Motorcraft 5w20 Synthetic Blend motor oil. Has anyone used it or uses it? Is pure synthetic available in 5w20 or just synthetiv blend? What does Ford actually use?
GREENBIOCH said:JDM why such a heavy weight?? I'm curious why you use that?? I use mobil one, but I use the 10w30.
drichard said:Someone tell me if I'm wrong but I don't think it would do any arm to your engine, but you should notice lower performances and lower mpg.
ndotym said:????????? Mobil 1 10/30 perfect for our car, 1 correction, 5/20 is light weight oil this why dealers use it for the gas milege...any this over 10/30 is and will make you vehicle run very poorly...
j/k. can anyone else input on this one?JDMsTangR said:i cant really take your word for this. maybe its just your post count.j/k. can anyone else input on this one?
GREENBIOCH said:I just wouldn't think you would need that heavy an oil unless your running a top fuel car or something. But I'm guessing if it's working for you, it is probably fine but I personally like the oil to be a bit lighter.
