MOVING ON NOW!!!!!!!!
stunner6910 said:
i'll look into the performer, i'm a huge fan of trickflow tho, will any of their intakes work with my set-up? but if performer is the best way to go, then i'll do that, i'll wait to see what you all say.
thanx
ps, killer, he told me that he used that gasket, i'm not sure tho, you might be right :D
the trickflow street heat is the match for the eddy performer. now i dont mean its an exact replica, so i dont want anyone coming on here and posting the 12000 differences between the two. :D
I KNOW the e-brock works well with the stock E7 head, as well as when you step it up with aftermarket heads and cam. I don't know however if the same can be said about the trickflow... I haven't seen anything here yet to support or dispute that claim.
There are 3 gaskets I know of from fel pro, the standard 1250, the larger 1262, and there is one other that is basically a thicker version of the 1262, but I can't remember the part number right now.
i called trick flow right now and they said to use this intake
http://store.summitracing.com/default.asp?target=emanufacturerSearch.asp&N=100
what do you real techs think? stick to performer or the street intake.
Killer, didn't see your post till after i posted the above part. (this is an edit)
I mean, if the performer works better I'll stick to that. I still have that e-303 at home waiting to be installed. i didn't install it since i need a bigger stall or until my buddy sells his 94 5-speed and i trade trannys with him.
Link goes to a blank page. The Street Heat is supposed to flow ~245cfm, the Track Heat ~265cfm and the Performer is somewhere about 220cfm plus or minus. For stock heads the Performer is a better choice.
