multitasking....
  • Thread starter Thread starter yeska68
  • Start date Start date Feb 1, 2004
Y
yeska68
45
Oakland ca
Feb 1, 2004
  • Feb 1, 2004
I had to replace my transmission and wanted to know what other parts can be replaced and checked on while this is out??? or what other parts on a mustang wear out about the same time the tranny goes out ?
i'd hate to have to replace something in 2 months that can be replaced now
any info will be helpful thanks
G
GaPonyFarm
663
Columbus, GA
Feb 1, 2004
  • Feb 1, 2004
Might want to check your universal joints...they're often overlooked. Check the flexplate to be sure you didn't bend it on removal. You can get a good look at the rear main seal of the engine, too. If you ever considered a higher stall converter, this would be a good time to do that change.
This is assuming that you have an automatic tranny... Disregard all except rear main, if you have a manual.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 1, 2004
  • Feb 1, 2004
A new or rebuilt torque converter is a must. A stall is OK if you like them. The previous history and use of the trans should be considered in a rebuild. If the old trans died a miserable death, be prepared is spend additional $$$.
Ford trans missions are generally vert durable and reliable.
calpolymustang
217
Santa Rosa, CA
Feb 2, 2004
  • Feb 2, 2004
a shifter can be changed while you have more room to work with, and while your linkage is disconnected
F
Fostang
1,400
Stockton, Ca
Feb 2, 2004
  • Feb 2, 2004
overdrive time?
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 3:42 PM
DadLife0724
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
