Mushy power brakes, Arizona Emissions
First, WOOT! My Stang runs again. I'll post a movie soon. :)
Now all I have to do is pass Arizona emissions. Any fellow AZ Mustangers know how difficult this is? Truly amazing that these idiots want testing on a 37 year old car.
My first reaction was, holy crap, I forgot how MUSHY the stock power discs are! Is this typical? Is there a cure? I'm thinking of going to Baer track front/rear, I sure had to have that expensive of a brake setup and still feel ... MUSH. I suppose I could ditch the booster, but ...
Opinions welcome. :)
thanks!
Lines seem okay. Brakes are solid as a rock when there's no power assist. :)
I'm not moving, the car relocated here from Las Vegas in July - it was never registered in Vegas and isn't registered yet here. I'm in Maricopa like you. I read about the bill on exemption for cars with classic car insurance, and that's what I have. However, everything else I've read said they haven't implemented it yet. Is that information outdated ?
thanks guys
I turn in the idle screw a half turn and up the idle to over 1000 rpm and the 68 302 passes. Make sure you have a clean air filter. Any smog equipment that came with the car has to be connected.
It's a silly test but the state needs the money. :bs:
Dark Knight said:
actually, they just passed the law.. not sure when it goes into effect, thinking either in Nov. or next year...
No way, i knew there was something trying to go through, thought it had to do with a rolling 20 year limitation if you have historic plates. Good news for me, I was worried I was going to have to try and pass. Pretty sure I wouldn't once i got the motor completed.
There's a pic of my brake booster. I didn't realize there were different ones for disc/drum?
The brake pedal stays mushy. I bled them a month or so ago, which firmed them up when the car's not running (and thus not boosted).
As to the emissions, I found an implementation schedule that had bureaucratic idiocy extending through December of this year without actual implementation yet. I guess that means I could get a one year waiver and hope it's gone next year. :)
I have the same booster thus the same problem. You need to purchase the unit without the band. I am going with the unit from Autozone. Check out their website and you will see the 2 models avialable.
Anyone interred in a booster for your drum brakes??
I passed
I passed. Couldn't take the test the first round through, the rear brakes wouldn't hold the wheels still on the rollers, and apparently they can't do an IDLE test with the car off the rollers. :)
One drum is out of spec, we swapped them around and got it to hold, took it back up there today and passed.
Scurly, AZ emissions requires an idle test and a 25-30mph at load test.
As for the booster, why is that the wrong booster? The Ford parts manual lists a Midland number with either Midland or Bendix as the manufacturer. I can't seem to find any other authoritative sources regarding the specific booster. Autozone lists Midland as "with clamp band". Is this just a swap to a lower powered drum brake booster?
Since I'm hoping to switch to Baer, which would probably mean a conversion to a miniature booster ...
The Bendix unit has tabs that are bent down to squeeze both halves of the unit together. I do not know what makes them different. My only guess is that disc brakes require more boost? :shrug: The first time I did the swap and used the correct booster the brakes were much more sensitive.
the booster does not matter for disc or drum, the only difference is the manufacturer. now the boost may vary between the 2 manufacturers but they will both work for disc or drum. check the factory manuals and you'll see that it really doesn't make a difference, both boosters were used for power brakes regardless if they were disc or drum
