mustang parts blow out gt40 heads, gt40 intakes, ford racing camshafts craziness!!!
mutiger93gt
Even if you run an E camshaft with trick flow heads you still need to notch the pistons, the trick flow twisted wedge heads need special pistons or a piston notching tool to fit. The valve are in different spots that the stock piston reliefs.
RARE NOTCH
73
Ohio
No you dont need to notch the pistons for an e-cam with trickflow heads. ive installed that cam in my buddys car and had no problems with valve clearance.I even installed a trickflow stage one cam in my notch with trickflow heads on the stock bottom end and had no clearence issues at all. and the trickflow head is the biggest valve head you can run with a stock piston to.
