Mustang Running like Crap!!!
  • Thread starter Thread starter 91StangGod
  • Start date Start date Dec 10, 2009
91StangGod
  • Dec 10, 2009
Hello all i need some help figuring out what is wrong with my mustang..
i have a 88 mustang gt convertable with 5.0 speed density..
here is my problem.. when im driving everything is ok but when i go to mash the gas it jerks and hesitates like it is missing or something.. and i have had it gone through with a fine tooth comb and nobody can figure out what it is.. here is a list of what people suggested and what i have replaces..
new distributor, fuel tank & pump, and sending unit, new fuel injectors, new ecu.. plugs wires, an auto shop had it for about two weeks and couldn't really find what is wrong with it.. all parts said are new not used.. and i have just about had it up to here.. as i just got the new fuel tank in and it doesn't do it as bad.. but still doing it.. now me and my cousin pretty know all you can know about mustangs and we can't figure it out.. as im getting codes with a scanner we bought from autozone which said the pick up coil in the distributor was bad so we replace the whole distributor and well i get the code again.. could there be a short somewhere.. which i was told that all the electrical was good as that was one of the first things gone through all electrical wiring tested for shorts or breaks all sensors are reading within range.. im out of idea's and i need the help of the mustang community to help figure this out before i decide to sell it..
HISSIN50
34
129
Dec 10, 2009
  • Dec 10, 2009
Did you clear the codes after you swapped dizzies?
To confirm, you have checked the TPS and BAP for opens in their operating range?
Are the 10 pins in good shape (not being stressed from motor rocking)?
Are the plug wires in good shape?
stangfanatic
107
Martinez, Ga
Dec 10, 2009
  • Dec 10, 2009
What kind of plugs did you put in? If they are platinum, swap them outfor some standard copper plugs and try that.
91StangGod
  • Dec 11, 2009
got the moroso 9mm wires and the E3 plugs which all of this didn't start happening until i put my 411 gears in.. as for the tps sensor i thought about that yesterday and going to get a ohm meter this weekend and check it out.. what is the BAP.. and i will check that as well.. Thanks guys all the help the better.. as i have put so much into this car and would hate to get rid of it.. and the location of the 10 pins.. also how do you guys put a picture of your cars so it can show up under you member name.. thanks again
91StangGod
  • Dec 11, 2009
How would i clear the codes.. as from everything i have seen about this matter is to just disconnect the battery for like 5 minutes.. and the battery was disconnected the whole time i was replacing the fuel tank.. (last weekend)
stangfanatic
107
Martinez, Ga
Dec 11, 2009
  • Dec 11, 2009
Besides using a scan tool to clear them, disconnecting the battery will do it. If it is a chronic problem, the code will pop back up.
HISSIN50
34
129
Dec 11, 2009
  • Dec 11, 2009
BAP: Barometric Air Pressure. It's one of the most important sensors your SD cars uses to determine stoichiometry.
Ten Pin connectors
91StangGod
  • Dec 14, 2009
where is the BAP sensor located? and Thanks to you all for you replies..
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Dec 14, 2009
  • Dec 14, 2009
Dead center of firewall. Looks like a little black box with 1 harness plugged in and 1 vac line running to manifold.
I'd def check the 10-pin connectors. Would be my #1 suggestion
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 14, 2009
#10
  • Dec 14, 2009
  • #10
on a speed density car its actually called a MAP sensor , since its measuring MANIFOLD absolute pressure , not Barometric pressure like on a mass air car
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2009
#11
  • Dec 14, 2009
  • #11
It does both on a SD. Its a dual function sensor. Buts it primary purpose is the MAP. Once the key is turned on, the MAP/BP sensor takes a Barometric pressure reading.
9
9050lx
33
#12
  • Dec 14, 2009
  • #12
Always have a spare good ECU.I like having good spares as I find it faster to swap simple items out rather than diagnose them.I would check the TPS first,02 sensors second,and check for fuel pressure and plugged lines.Usually obvious overlooked simple things i have found.
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
  • dan50
  • Jul 18, 2026
dan50
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
