Mustang stalling
  • Thread starter Thread starter cool92gt
  • Start date Start date Apr 13, 2011
cool92gt
30
CALIFORNIA
Apr 13, 2011
  • Apr 13, 2011
Me and my son just purchased a 1990 mustang gt. When we come to a stop the car stalls. Fast or slow stops it just stalls. Can anyone give me some advice on what to do.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 13, 2011
  • Apr 13, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
BlackGT89
774
Huntsville, AL
Apr 13, 2011
  • Apr 13, 2011
Could be lots of things, so go through the checklist as suggested. But a good place to start would be to clean your IAC (Idle Air Control) or if you prefer IAB (Idle Air Bypass). The problems occurs when you get a carbon build up inside the device. If the car has a cam in it, then that could complicate things a bit.
Here's a link: Ford Mustang IAC IAB - Solving your idle problems
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 14, 2011
  • Apr 14, 2011
Vehicle speed sensor might have somthing to do with it also.. What is your idle set at? Sometimes if it is to low it can cause problems.
cool92gt
30
CALIFORNIA
Apr 17, 2011
  • Apr 17, 2011
thanks
hey thanks jeepguy00.. i bumped the idle a bit and it stopped stalling...thanks again
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 17, 2011
  • Apr 17, 2011
You are not supposed to use the idle screw to raise the idle.
See the See the "Surging Idle Checklist for the right way to fix idle/stall problems.
It is possible that you have a bad VSS. Without dumping the codes you will never know.
The quick and easy way to dump the codes is in the checklist too, and all you need to do it is a paper clip! The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
