Does that mean the v6 transmission is not compatible with the gts engine ? As long as it will run without messing anything up I'm not worried about the power
You never clarified Auto or manual. If it is an auto, I would "guess" it would bolt in. Hopefully, someone else will jump in and say. Not sure if the spline count and length of the shaft is the same. Pretty sure the bolt pattern is the same.
