it only does it under a load or at wide open throttle. if you roll into it it hessitates a very little but then its fine and works like its supposed to
1. Drive to Autozone of discount or what ever is close to you.
2. Have them scan your OBD II for free
3. If you have codes start trouble shooting from there.
4. it may be your MAF so you can clean that. be CAREFUL doing this because the coating is sensitive so you do not want to use brakeclean or anything like that. you should be safe with carb cleaner or some places carry MAF cleaner
