My 95 vert stalling Help!
a-spec FD
12
I just bought a 95 5.0 vert 5speed with 69k on it. When I drive it the motor feels very strong and the power is very steady. But now after a few miles into driving when I come to a stop the car just dies! It won't start, the battery is working, starter motor is trying, it just won't start. I gave the car about 3 min., tried and it starts like there was never anything wrong. The guy I bought the car from says it's been sitting awhile. What is wrong with my car, how can I fix it? Thanks Guys.
try setting you idle to 900 rpm's with the iac bleed screw a 1/4 turn out. its more of trial and eror but that has seem to be my luck and i have "the dreaded e-cam" get the car up to opperating temp. unplug the iac before you set it. then disco the battery for like 5 mines and you should be good.
Sounds more like the common TFI module and/or coil taking a dump. The symptoms you are describing are typical of this. You can test those at most parts stores or have a shop test them.
if that is an option make sure you tell them the car is obd 1 and the connection is by the passenger side firewall. good luck
