today was a cold morning and when i turned my heat on and the fan to hi i got nothing. got home today and look4ed into it alittle. im getting power at the switch but my motor just isnt coming on. what should i do?
Sounds to me like your blower motor resistor is bad. Its located under the glove box, screwed into the heater case near the motor. Look for a rectangle shape with a screw going through each end and a square plug in. Remove it and it should have some coils on the other side. Check for power in and out of it to be sure though.
Buy new car. No, um is it working on the other settings? you sed u turned it to high and it didnt work. How about a fuse? Are other electrical problems happening? Do you want some food? how about a pie? Okay thats going off topic i'm just really hungry.
If the resistor was bad it would only work in high, becaue the resistor is bypassed on hi. (full power). Unless of course it is so fried the wiring is the problem. Are you getting power to the motor? If so are you getting ground from the motor? If so you have a bad blower motor.
yeah cheack for power at the motor,,like it was said,if it only worked on high,the blower speed resistor is bad,if you have power,try to smack the motor with a mallet,it might have a burn spot on the armature.
