  • Mustang Sound & Shine All
My cd player doesnt work when the car is running?
  • Thread starter Thread starter fivelitercoupe
  • Start date Start date Apr 8, 2008
fivelitercoupe
132
Longwood, Florida
Apr 8, 2008
  • Apr 8, 2008
My cd player and radio works just fine when the key is just on and the car isn't running but as soon as you start the car the cd player doesn't work. i figure its got to be something in the head unit or a short in it somewhere, I'm no wiring expert or stereo genius so I really don't know. Any info or input would be greatly appreciated, thanks for the help guys...
Brett
Supradude26
86
  • Apr 8, 2008
Does the unit not turn on when the car is running? The only thing that I can think of is a bad voltage regulator. Some radios will not work properly if they see too much voltage. I would take the car to a autoparts store and have them check the voltage when off and when running.
Speedracer06288
26
Hollywood, FL
Apr 8, 2008
  • Apr 8, 2008
If it's a after market radio. You need to make sure you are getting a constant 12 volts to the Yellow wire. The red wire should only get 12 volts once you turn the key to ACC position. And of course make sure the black wire has a proper ground. Those are the three most important wires to make the radio work right. If that's all right then it's something wrong with the radio
fivelitercoupe
132
Longwood, Florida
Apr 8, 2008
  • Apr 8, 2008
Great information, cant wait to take a look at the wires and see what kind of voltage its getting. Its weird though when the car is running the cd player is actually working, it turns on but theres no sound, it runs through the songs but with no music if checking those things doesn't work then I'm probably gonna assume its the head unit.
Brett
Supradude26
86
  • Apr 9, 2008
This is unusual. There are no factory radio wires that change when the car is acc mode vs running. As long as the red wire on the back of the deck is hooked to accessory 12volts, the yellow wire to constant 12volts, and the black to ground, you shouldn't have any problems. Do you know if you have a factory amplifier? That would be the only other thing that could be the cause of this type of problem.
fivelitercoupe
132
Longwood, Florida
Apr 9, 2008
  • Apr 9, 2008
I didn't get a chance to mess with it today but it does have the factory amp and my friend who put the cd player in did all kinds of wiring to either make the cd player work with the factory amp or bypass it, I'm not too sure. I would think it would be weird for the amp to not work when the car is running but it works when the key is on... Thanks again for help, hopefully i can look at it tomorrow
Brett
Speedracer06288
26
Hollywood, FL
Apr 9, 2008
  • Apr 9, 2008
sounds like it's your amp turn on wire or antenna wire. Usually blue and white from the head unit and Blue. Try connecting the Blue an the Blue with white together from the head unit. When you play a cd the radio will not send 12 volts to the blue wire, only when you play the radio.
Supradude26
86
  • Apr 10, 2008
Another way to check and see what may be wrong is to connect the wire that is currently hooked to the blue/white and temporarily connect it with the yellow to give the amp constant 12volts. That would rule out a problem with the amp turn on lead.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
J
Windows won’t go up when car is running
  • Jraesims
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
  • brandyn200
  • Jun 20, 2026
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
