My engine sounds like a semi?
  • Thread starter Thread starter FearThis
  • Start date Start date Sep 3, 2005
F
FearThis
  • Sep 3, 2005
Sometimes when i drive my car around a lot my engine starts to sound like a semi trying to accelerate everytime i switch gears and accelerate. it will continue until i let of a little and then its fine. Im confused with this problem. it only seems to happen when im driving around a lot and i also recently just swapped out the stock intake for a cold air intake. i never had the problem with the stock air intake. Im just getting into moding my car and have had no problem with the car really. I havent changed the oil in a couple of months so im wondering if thats the problem.
Anyone that can shed any light on my problem would be a big help. thanks.
93 LX 5.0 5 speed
R
Rerun
312
South Bay, California
Sep 3, 2005
  • Sep 3, 2005
Sounds like you got a little pinging going on. Did you try taking off the cold air intake, and putting the stocker back on just to see if that's the problem? You may be running lean which is causing the pinging. A buddy of mine had an F-150 which he was describing sounded like a diesel truck and turned out it was running lean and pinging. This may not be it, but just a suggestion. Yank a few plugs and report back what you see.
As always, correct me if I'm wrong fellas.
L
luckythirteen13
648
Anaheim, CA
Sep 3, 2005
  • Sep 3, 2005
did you reset the computer when you put the cai on?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 3, 2005
  • Sep 3, 2005
exhaust leak?
HISSIN50
34
129
Sep 3, 2005
  • Sep 3, 2005
My random thoughts:
The noise could be from the CAI - you are hearing more intake noise now.
Or your mech fan is locking up a bit tight. If you have a metal fan blade, that will make some serious noise too.
Good luck.
Aliate X
602
Rockland NY
Sep 3, 2005
  • Sep 3, 2005
I just think its your mechanical fan turning on which is normal.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
  • brandyn200
  • Jun 20, 2026
AeroCoupe
