My last electrical gremlin? One brake light...
  • Thread starter Thread starter 66 Restomod
  • Start date Start date Sep 23, 2008
66 Restomod
203
Raleigh, NC
Sep 23, 2008
  • Sep 23, 2008
I think all electrical items on my car are working after putting it back together. Except for the passenger brakelight. The passenger tail light works ok (dim though) and the passenger flasher works ok with emergency flashers on. But no brake light. (I haven't checked the regular turn signal on that side but thought it would work since the emergency flashers do.)
All wiring, bulbs, etc are new but I've learned that doesn't matter (installed 2 defective, mis-wired parking lights on front). Any idea to narrow my uninstall-and-replace search, which is kinda expensive? Thanks!
carefact0rzero
49
columbia, sc
Sep 23, 2008
  • Sep 23, 2008
you say all the wiring is new, is it stock style or painless, ezwire, etc... ? and is the turn signal switch new as well?
66 Restomod
203
Raleigh, NC
Sep 23, 2008
  • Sep 23, 2008
It's new stock style. I just unplugged the old and plugged in the new. Everything replaced but the main harness which was not butchered at all. New tail light buckets too. New OE turn signal switch, not the repro.
Tim65GT
1,149
West Texas
Sep 23, 2008
  • Sep 23, 2008
If the flasher works, then the wiring to the back is ok.
I didn't have 4 way flashers on my '65. Not sure how the '66 has the switch intergrated into the wiring. Is is built into the column, or is it a separate switch?
The rear signals get the power individually from contacts in the sgnal lamp switch. If the voltage is good coming out of the column connector, then I would look at the flasher wiring/switch.
66 Restomod
203
Raleigh, NC
Sep 23, 2008
  • Sep 23, 2008
The emergency signal switch is in the glovebox, looks like it was installed at the dealer back in the 60s. The turn signals should work, it's the passenger brake light that's not working. The green/blue wire carries the turn signal and the brake light to the passenger rear I think. The problem must be under the dash from the brake switch to the green/blue wire, I'm guessing... Is this possible?
carefact0rzero
49
columbia, sc
Sep 23, 2008
  • Sep 23, 2008
you need to check to see if the pass. side turn signal works or not, it'll help us figure out what we're dealing with here.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 23, 2008
  • Sep 23, 2008
Could be a bad bulb. Double check the bulb and test for current at the bulb socket. If you got nothing there then work backwards.
You can also go the other way and work forwards but I don't like going that route myself unless I suspect the problem to be closer to the start of the circuit.
carefact0rzero
49
columbia, sc
Sep 23, 2008
  • Sep 23, 2008
from looking at the diagrams, you've got your turn signal power coming from the back of the ignition switch into the flasher, then into the column connector on a blue wire, your brake signal is coming from the brake switch on a green wire. the wire coming out of the turn signal switch to the column connector and back to the pass. tail light should be orange and blue. the brake and turn signal signal are both sent on that wire. i'd check the connection at the column connector, maybe that is loose or something. if one of your brake lights are working then power from your brake switch is good. you're probably looking at a bad turn signal switch.
Tim65GT
1,149
West Texas
Sep 23, 2008
  • Sep 23, 2008
No, If one brake light works, it’s not the brake switch.
The schematics I have show an Orange/Blue wire, but regardless, if both flashers/signals work, it’s not the wire or the socket or bulb.
First check all signals and then the 4-way flashers and report back.
Have someone watch the lamp (or set up a mirror) so you can see the bad brake light. Hold the brake pedal and slowly move the signal lever up and down to see if the light comes on.
It appears something may have happened to your new signal switch, or perhaps a couple wires are swapped at the plug.
66 Restomod
203
Raleigh, NC
Sep 25, 2008
#10
  • Sep 25, 2008
  • #10
Fixed... maybe
I found that the passenger rear brakelight and turn signal did not work. But the turn signal indicator in the dash flashed normally and the running light at the passenger rear did work.
So I was fiddling under the dash and tightened the connector of this orange Y-connector where it leads to the tail light harness (although the connector seemed already tight). And now I have lights on the passenger rear. The connections at all the bullet connectors are crummy even though everything is new, meaning a slight twist here or there and various lights go out.
Can I use dielectric grease to make the connections better at all the bullet connectors? Will the grease transfer electricity or just keep moisture out?
Also, the passenger rear light is dim, in all it's functions. I replaced the tail light bucket, bulb, and all wiring as I said earlier... Also, the ground seems ok. (The backup light below the bumper works fine off the same ground.) Could this be caused from a poor positive (+) connection?
Thanks for all help!
iskwezm
4,159
20
79
Rowland Heights,California
Sep 25, 2008
#11
  • Sep 25, 2008
  • #11
I've had a left brake light out for YEARS, just too lazy to replace the t/s switch
66 Restomod
203
Raleigh, NC
Sep 25, 2008
#12
  • Sep 25, 2008
  • #12
I hear ya and if I hadn't spent the time and money to replace everything, I wouldn't expect it all to be working.
Just trying to get it right since the time and money has already been spent.
MrBobMarley
460
Ft Myers, FL
Sep 26, 2008
#13
  • Sep 26, 2008
  • #13
My lights were out recently....turned out the plug worked loose on the brake light switch. Also, if I remember right dielectric means an insulator. Maybe try sandpaper first?
66 Restomod
203
Raleigh, NC
Sep 26, 2008
#14
  • Sep 26, 2008
  • #14
Thanks i think i will try unplugging everything, lightly sanding the connections and plugging back in. I've been looking around online and that's right, dielectric does not conduct electricity. Apparently there's something called conductive grease for that. I had never heard of that before.
E
ETEL64
51
NJ REFUGEE, HOUSTON, TEXAS
Dec 18, 2009
#15
  • Dec 18, 2009
  • #15
Before you go sanding the tin plate or other plating from the terminals. Try using steel wool and then use the Conductive grease. The copper under the palting is affected more by the elements than the plating. Also use the same steel wool and grease on the screw.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Dec 18, 2009
#16
  • Dec 18, 2009
  • #16
I'd use Brasso, Q-Tips and a toothbrush, and then a little silicone grease when putting them back together.
66 Restomod
203
Raleigh, NC
Dec 18, 2009
#17
  • Dec 18, 2009
  • #17
Fixed, Thanks
This is one of a few posts that have been solved since I first posted in '08. Rusty67 gets the prize for this one. It was a bad bulb. The second bad LED in a row on that side apparently. So I used a standard 1157 and everything worked again... Thanks all!
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 18, 2009
#18
  • Dec 18, 2009
  • #18
Some forums have a function that can mark a post as a solution to the problem. That would be sweet to have for this forum.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Wiring diagram
  • 78 Mach1
  • Sep 24, 2024
2K
1974 - 1978 Mustang II Talk & Tech Jan 24, 2025
welder4956
O
Getting things to work and display correctly on my cluster. I would appreciate anyone's two cent's worth.
  • OfflineHomestead
  • May 7, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2024
OfflineHomestead
O
M
Resolved 2010 V6 Taillights wiring issue
  • MRMRacing
  • Dec 7, 2024
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Dec 8, 2024
MRMRacing
M
