  • SN95 4.6L Mustang Tech
Mystery sound...
  • Thread starter Thread starter tonys5.0
  • Start date Start date Jun 29, 2006
tonys5.0
122
Jacksonville, FL
Jun 29, 2006
  • Jun 29, 2006
When I got in my car this afternoon and turned it on, there's a loud high pitched droning noise that sounds like wind blowing through a pipe. This noise is loud enough that you can hear it a 1/2 block away.
I opened my hood and the noise is coming from the front right passenger side somewhere around the wheel area. The noise is so loud it hurts my ears and is too difficult to pinpoint. The best description is a very loud "high pitched" droning noise like air rushing through a pipe at a high speed. I've had the car two years and never heard anything like this before.
Anyone have any advise on this issue? I found nothing when I did a search.
The car is a 04 gt 5sp with a jlt cai with maf inside fenderwell.
DTNODYA
831
  • Jun 29, 2006
Um ... could it be your " jlt cai with maf inside fenderwell." ??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 29, 2006
  • Jun 29, 2006
Sounds like an idler pully that is very close to seizing up to me.
tonys5.0
122
Jacksonville, FL
Jun 29, 2006
  • Jun 29, 2006
I don't think so. The JLT setup has been on since last year. I'll check the idler pully. The car only has 28000 miles on it.
DTNODYA
831
  • Jun 29, 2006
Sorry, my post sounded 'smart-assed' .. what I meant to say was check your filter and maf to make sure that nothing is loose and what not.
2002GreyGT
481
Raleigh, NC
Jun 30, 2006
  • Jun 30, 2006
Wind going through a pipe sounds like something with your CAI set up. Maybe you poked a whole in your Filter and its kind of sucking air through that hole, like a straw.
That is where I would start.
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jun 30, 2006
  • Jun 30, 2006
Maybe someone put a S/C on while you were sleeping?
Does the pitch of the sound increase with rpm's? Does the noise change at all with increased rpm's? I know you said it was loud and hard to pinpoint because it was painful....but suck it up and get it done! J/K!
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jun 30, 2006
  • Jun 30, 2006
Remove everything before your MAF and run the engine for a short period of time (short because no air filtration). If the sound continues, then it's not your filter.
BooWFO
991
Louisville, KY
Jun 30, 2006
  • Jun 30, 2006
Ok has anything happened to the car? Does it do it driving or sitting still? Does it change with roadspeed or rpms?
Few things to check
If you've taken a bottoming out might have knocked you manifolds loose and causing an exhaust leak the metal gaskets make a very strange sound when they first start to go.
Idler pulley like other have said
Major belt slippage
Throwout bearing starting to go
Intake leak somewhere. IE CAI, Plenum, Tb, ETC
Wheel bearing ( of course you'd only hear that going down the road)
Altenator going out ( I've seen some make all kinds of noise when they start to go)
exhaust leak
EGR leak
or maybe the Supercharger Fairies visited you. If so please send them to my place
ultrashock2112
100
Vancouver, Canada
Jun 30, 2006
#10
  • Jun 30, 2006
  • #10
Maybe the A/C compressor? Could be on its way to seizing...
T
Torinalth
952
Clayton NC
Jun 30, 2006
#11
  • Jun 30, 2006
  • #11
i have the same noise, and i cant figure it out either... I am going to take a stab at a few occurances that might help decide if we are hunting the same problem or not.
my noise happens when its usually warm out, after the engine has heated up, and only at idle... once i get the RPMs passed 1k it goes away. the sound to me doesnt remind me of air anything, its kinda more along the lines of taking a martini glass, weting your finger with a lime, and running it around the edge of the glass making that reerberation sound.... but its loud.
as far as idler pully, i soaked all my pullies with PB blaster but never went away when the engine is on until i get the RPMs up passed 1k. it drops back down, and the noise comes back. its not an everyday noise, it just comes on, and after that it doesnt go away till it cools down.
just something to think about. mine kinda sounds like its on top of the engine... just cant seem to pinpoint it myself either... been living with it till this weekend when i can spend all day poking at various parts.
Torinalth
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
HUGE Backfire on startup, worried i hurt something
  • 67fox
  • Sep 16, 2024
1965 - 1973 Classic Mustangs -General/Talk- Sep 23, 2024
Realmongo
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
