Nagging exhaust leaks
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
I've been battling an exhaust leak the past few months. Recent roadway construction has caused some component of my exhaust to develop a slight leak. I can hear it plain as day when the engine is under load. It's small but very annoying.
My exhaust is stock except for a cat-back. Twice i have removed and reinstalled the cat-back trying to get rid of the leak. I still have it.
Anyone have any good methods of locating leaks? I have it narrowed down to the passenger side, but i can't tell if it's coming from the rear of the front of the car.
It's getting annoying as hell and i want to fix it!
Yeah, no one ever cares to do as good a job as you do for your own car...
Do you know someone with a lift that you can safely run it on and look/listen for the leak?
Another way might be to seafoam it. When the seafoam burns off it makes loads of smoke that may reveal the location of the leak...
I've been under the car with it running and had someone rev it, but under no load there is no leak. I only hear the leak when the engine is under load...in other words driving or if i slip the clutch out under low rpms's.
I can hear it but i just can't figure out where it's coming from.
I'm curious about this seafoam. Where can i get it?
AutoZone, Napa...
You can use it three ways:
-add to oil 100 miles before change
-let it be sucked into the intake
-add to gas
Do a search for more info...
I think the towel method sounds like it will work better that was posted.
just get someone to cover those tail pipes while you are under, or near, and you should hear it at idle even. if not, just have them rev it a bit and you feel around at where the pipes join. Just high temp silicone it if you cant bolt it together to stop it. that red stuff works pretty good for that. what kind of catback?
mity2 said:
where is the leak? is it where mid-pipe connects to catback or where mid pipe connects to manihold?
Not sure. I've only installed a cat-back, so i can't see the midpipe to manifold bolts loosening up.
It can also be where the tailpipe joins the muffler. I am going to weld those on in a couple weeks, i just want to make sure the leak wasn't elsewhere in case i needed to take it off again
well, due to new catback, it could be pulling on the manihold to mid pipe connection. But i would tighen every connection of catback first.try simple thing first, befor take it to shop.
