Nagging Hot Start Issue
Aug 13, 2017
Help! I am having a hot start issue. I have seen multiple forums and checked/replaced recommended "problem parts". If I cut the car off after after 180°, no start. Wait 5-10 mins, starts up. No problem with cold start. Holding the pedal to the floor, nothing different. ** When this happens, I do not hear the pump prime**
New Fuel Pump
New IAC
New coolant sensor
New bap sensor
New Distributor w/ignition module
New Starter
Swapped out ECU
Checked grounds & added more grounds
No Codes
I had the same problem in my 1987 fox. I replaced the fuel filter and it was filthy. Ever since the car has run stronger than ever. I replaced it about 4 months ago. Try this if you haven't already it helped me out and I have made numerous long trips with no problems since.
Update: Fixed. It must have been the bad connection (possible other contributing factors) on the fuel pump relay. The previous owner attempted to repair the stock wires off of the pigtail. The parts that were replaced probably needed to be anyways. Thanks for the help guys!
Reactions: a91what
