  • SN95 4.6L Mustang Tech
name three things that would?
  • Thread starter Thread starter maxima
  • Start date Start date Oct 7, 2008
M
maxima
146
  • Oct 7, 2008
name three things that might be causing a ringing chain dragging noise underneath my 04 gt only when the car is moving. usualy between 2500 and 3000 rpms. not a constant noise but everytime i drive it will happen..
fasterthanthem
Hampton, VA
Oct 7, 2008
  • Oct 7, 2008
Loose bolts/nut along the exhaust somewhere?
Or possibly the exhaust rubbing on the chassis/body?
Stark77
501
Tallahassee, FL
Oct 7, 2008
  • Oct 7, 2008
loose O2 sensor
M
MrCarlson
Fargo, ND
Oct 7, 2008
  • Oct 7, 2008
Check the exhaust heat shields, they can make some funky noises when they are loose or bent/rubbing.
Does it happen more over rough roads or is it more based on engine or vehicle speed?
-MrCarlson
RedDaemon
3,470
9
108
Atlanta, GA
Oct 7, 2008
  • Oct 7, 2008
you sure its not a lose spark plug?
mransr
1,188
36
98
Riverside, SoCal
Oct 7, 2008
  • Oct 7, 2008
+1 on the spark plug
or maybe a cat coming apart (if you have cats)
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,114
224
Massachusetts
Oct 7, 2008
  • Oct 7, 2008
brake splash shields?
R.J.
813
Warwick, Rhode Island
Oct 7, 2008
  • Oct 7, 2008
Metal EVAP line fell out of its clip above the drive shaft? (happened to me)
9
98coop
tennessee
Oct 8, 2008
  • Oct 8, 2008
cat shield, header bolt, o2 sensor loose
M
maxima
146
#10
  • Oct 9, 2008
  • #10
02 sensor being loose? how would i know that?
M
maxima
146
#11
  • Oct 9, 2008
  • #11
-MrCarlson
where are the heat shields on the exhaust? its really not on speed it happens mainly between 2500 and 3k. but it could happen at other rpms. rough roads dont make a difference
M
maxima
146
#12
  • Oct 9, 2008
  • #12
its coming from under the car. i dont think it could be the spark plugs
fasterthanthem
Hampton, VA
Oct 9, 2008
#13
  • Oct 9, 2008
  • #13
He might not have the heat shields with the aftermarket H or X pipe he has. When I put on my Bassani X pipe I never put the heat shields back on.
M
maxima
146
#14
  • Oct 9, 2008
  • #14
i had an aluminum drive shaft put in yesturday i think the mech would have noticed that??
M
maxima
146
#15
  • Oct 9, 2008
  • #15
i have a mac prochamber i dont think i have the sheilds anymore
M
maxima
146
#16
  • Oct 9, 2008
  • #16
thats the metal peice infront of the brakes? idk i tried messing with those, i dont think its that. good idea though
oxfordgt
288
Clarksville, TN
Oct 9, 2008
#17
  • Oct 9, 2008
  • #17
Are the joints in the exhaust hitting the floor board?
Smokeurhonda
457
Maryland
Oct 9, 2008
#18
  • Oct 9, 2008
  • #18
You sure the car isn't pinging? It can make that noise you discribe. You say that it usually happens between 2500-3000, but what kinda throttle are you giving it?
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
