Nasty noise under load (ENGINE)
  • Thread starter Thread starter mustang925.0
  • Start date Start date Oct 20, 2010
M
mustang925.0
9
  • Oct 20, 2010
ok, im brand new here so to start off ill give alittle info about the car.. Got a 92 lx 5.0 ....converted to T-5 ( original auto computer still in it) minor upgrades include msd distributor and cap, msd coil, full BBK cold air, 2 1/2in off road H-PIPE with series 40 flowmasters (no cats).. and just recently installed new clutch quadrant( aluminum), clutch cable, new clutch stage 2 zoom, and steel bearing retainer. . also have a new flex fan up front ( dont think that really matters). ok, now for the first problem i have of about 10! lol.. ok, so going down the road in any gear when under load ( wont do it going downhill) at about 4 grand i get a sound from the engine bay that sounds like ball bearings being shaken in a steel can.. i was told that it may be crank bearings but im not too sure, now i do have a slight tap from the drivers rear valve cover, i imagine its just a rod tapping? i also was told that these 5.0's are pretty much bulletproof. which i have verified slightly because i literally run this car hard. (5200rpm) constantly. so needless to say im pretty brutal to it... i just need to get some opinions on what this sound may be. iw ould hate to be left stranded somewhere, so if i can get a definent (or somewhat near) answer ill just rip the thing apart and start upgrading... any help here would be awesome!! then i can introduce some more of my problems!
L
Lawbreaker5.0
543
Texas
Oct 20, 2010
  • Oct 20, 2010
Sounds like it's pinging. What's the timing set at and what grade fuel are you running?
93project
549
52
38
El Paso, tx
Oct 21, 2010
  • Oct 21, 2010
yep, detonation.....
needs to be checked asap before it grenades your engine. Oh and uh, I know we all love our fox bodies, some more than others, but don't treat her like a bit*h. Unless your engine is new, which it sounds llike it isn't, you're just pushing a rebuild up in the schedule.
Kdubslugga
1,515
Akron, OH
Oct 21, 2010
  • Oct 21, 2010
I 3rd the notion of detonation! Rattle under load, 9 times out of 10 is detonation. What gas are u running 87? If so, burn it all out and run 93. Also, check your timing. It should be no higher than 14 degrees. Id set it to 10 just to verify its detonation, but im saying it is!!
M
mustang925.0
9
  • Oct 21, 2010
i have yet to check the timing. and yes, i am running 87 octane..just filled er up too damn... friday after work i will be checking the timing.. along with installing a new tps sensor because she's throwing me some funky codes.. as soon as i check the timing, i will be getting back to you all, thanks for the help
!!! greatly appreciated!!.. and by the way, its very hard to not get into the pedal all the time when you got a car like a mustang!! lol this is my first mustang, had her for about a year.. and not to mention the fact that everyone in a halfway sporty car that sees my 5.0 wants to race and needless to say they all drive away disappointed!! smoked a porshe yesterday! ha
Kdubslugga
1,515
Akron, OH
Oct 21, 2010
  • Oct 21, 2010
Im willing to bet you run that 87 out of there start using 93 your pinging or rattling will be gone!!
Your addiction will only get worse bud!!
L
Lawbreaker5.0
543
Texas
Oct 21, 2010
  • Oct 21, 2010
A porshe? How much horsepower do you have?
93project
549
52
38
El Paso, tx
Oct 22, 2010
  • Oct 22, 2010
Kdubslugga
1,515
Akron, OH
Oct 22, 2010
  • Oct 22, 2010
93project said:
+1
Coulda been an old 944.
M
mustang925.0
9
#10
  • Oct 23, 2010
  • #10
it was definently a 911. and honestly i dont know what im pushin as for horsepower. i know this mustang has alot more pull than most 5.0's ive been in.
ok. so i got a new tps sensor (nothing to do with this peticular problem) so i took both leads off the battery to reset the computer.. an hour later i get in the car, start cruising down the highway, and when i get on it now, theres no rattling sound.... which i found quite odd and which would pretty much verify the dentonation ( i think) since the car also resets timing..correct?
M
mustang925.0
9
#11
  • Oct 23, 2010
  • #11
ok.. update here. I Finally checked the timing with the spout out. it was at about 20 DEG. BTC.... adjusted her to 13BTC, it idled like new but fell on its face when i tried to give it any gas ( spout out) and wehn i put the spout back in, it idled *****ty and ran beautifully. . after taking it down the freeway, there is no more detonation!! none whatsoever. thats everyone for the help.. greatly appreciated!! i am going to post another thread with another problem that i have with the tps.. go figure! lol
Kdubslugga
1,515
Akron, OH
Oct 24, 2010
#12
  • Oct 24, 2010
  • #12
HAHA 20 degrees advanced and 87 octane?? Thatll cause pinging all day!! glad u got that squared away!
G
gearhead101
23
lakeland,florida
Oct 25, 2010
#13
  • Oct 25, 2010
  • #13
my car did the same thing right went i bougt it it was at like 18btdc so i set it at 10 btdc and ran all the fuel out then top it off with 93 and started adv the timing intill i had det then that put me at 13.5 btdc it does make i differents going from 10 to 13.5 with good fuel.
M
mustang925.0
9
#14
  • Oct 25, 2010
  • #14
thanks for all the help! and even though the timing was way off it still ran pretty well, needless to say it runs even better, and the exhaust sounds quite different, more like a 5.0 should sound! another day, another lesson learned!
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
