nasty vibe while driving
KeithGT
15
BG,Oh
as it states, while cruising around 65-70, its not to bad, you can tell its there, but livable, downshift to 4th and take it up to about 95-100 (:Track:) and it feels like the car ganna vibrate itself to death. any ideas? already got the wheels balenced, but to no avail. i know it could be a ton of things, but just wondering if mustangs have anything thats "common" that could be causing this before i go throwing money that i dont have at it. thanks in advance.
Keith
Shakerhood said:
Is it in the seat of your pants, or through the steering wheel?
its coming from both, and the shifter. no nothings been changed, just got the car about 3 weeks ago, just trying to get all the little things fixed before i start modding it.
i have a vibration to but it seems to be in the steering column. When you move the steering wheel in an up and down motion it has a little play, and when i brake coming from high speeds it shakes erratically. Anybody have any ideas?
nxb88 said:
.... and when i brake coming from high speeds it shakes erratically ...
Hijackin' a thread eh ....
Well if it only happens when you brake .. I'm gonna suggest checking the brakes ... try looking at the rotors to see if they're warped.
To the original poster ... vibrations are a B.
The best way to find the culprit when you've got the shakes everywhere is through the process of elimination ... sometimes a compounding of two or more items out of spec can cause the vibration.
To answer your initial question, no there isn't any "most common" issue with vibrations and your Mustang ... I'm with you, they are the most annoying problem to track down.
Could be anything from a harmonic balancer to an old wheel bearing in the diff ... and everything in between :(
well that sucks, lol, oh well, im ganna start checking every moving part tomorrow morning, starting with them u joint bolts, i did check the u joints at one point, absolutly 0 play. i dont know, kinda wondering about my wheel bearings, so im ganna check them tomorrow. thanks guys
keith
yeah hijacker! :Zip2: lol, j/p, yeah that defiantly sounds like warped front rotors
