need a combo
  • Thread starter Thread starter yelbigbirdlow
  • Start date Start date Mar 9, 2004
Y
yelbigbirdlow
71
DFW Texas
Mar 9, 2004
  • Mar 9, 2004
im looking for an engine combo! Let me start out buy saying that i plan to run a combo with a twin turbo (t3) setup. Im looking for a combo that is a little better than one w/aluminum trick flow heads with an F cam with 1.6 rockers. also what is a good intake manifold to go with, I like the look of the GT40 but im hearing that a cobra is better do to the fact that it can be ported. should i go with one of these two or another. The combo that im asking for is one that i can drive on a daily basis, not full out Track. i want to run about atleast a low 12, but my goal is more of a mid 11. HELP!!!!!!
Y
yelbigbirdlow
71
DFW Texas
Mar 9, 2004
  • Mar 9, 2004
i mean on drag radials when i say 12s and 11s
Legendary
1,925
City of Angels
Mar 17, 2004
  • Mar 17, 2004
This interest me because I too plan on going TT. bump
M
matm347
2,056
  • Mar 17, 2004
You wont need much at all to get a TT setup into the 12s, a stock setup can do that.
As long as you keep the boost down, the stock block will be OK, just stay far away from detonation!
But AFR 165/185s, Edelbrock/Holley intakes and a custom cam would be better than the "TFS head" setup.
I would go with the 165s and an RPM intake, and just crank up the boost when/if needed.
What boost levels do you plan on running?
Make sure your fuel system is up to the task.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
