need a little help
88GTtom
198
Woodbridge NJ
ok, i went home to nj and got my motor finally, rebuilt block, gt 40 aluminum heads, e 303 cam cobra upper and lower, 1.7 roller rockers 24 lb injectors adj fuel pressure regulator, i believe it is a 73 mm mass air, but not sure, ok the car runs great, but after cruising home when i would come up to a light or stop sign and i throw the car in neutral, it revs up, and then dies. ill start it back up and it will start acting up. i tried turning the idle up so it would stop, no luck. i think my pressure is at 40 on the adj reulator. is it to high, anyone know what i should do. pissing me off, ill mess with it tomorrow after work, but would like to get some ideas tonight. later tom
