need emergency help
  • Thread starter Thread starter saleen9899
  • Start date Start date Nov 21, 2006
saleen9899
  • Nov 21, 2006
I was messing with my headlight switch last night becuase the dash doesnt light up when turn on my headlights. (problem 1)
and i got frusterated and pulled all the wires out of the switch....i dont have a diagram so i dont know where the wires go now. the chilton's diagram is wrong, and every diagram i find on the internet it wrong. none of them have the correct wire colors or WHAT prong they plug into on the switch. (problem 2)
there are 7 wires and 9 prongs on the switch....no wire harness because it melted and had to be replaced.
what i need is for someone to tell me what color wire goes with which prong. (before it gets dark out or i am stuck at work.)
ford wants $200 to fix it.
saleen9899
  • Nov 21, 2006
the harness wasnt replaced just removed
Bosko5.0
1,067
longwood, FL
Nov 21, 2006
  • Nov 21, 2006
welcome to :SNSign:
and here you go
and heres my harness its funny how they melt
saleen9899
  • Nov 21, 2006
haha you rock!
i JUST got a faxed diagram from the switch manufacturer as well. which corresponds to your picture
unforunately the *dash board* STILL doesnt light up when the headlights come on?
what is the fix for that?
(YES fuses have been checked repeatedly)
Bosko5.0
1,067
longwood, FL
Nov 21, 2006
  • Nov 21, 2006
your switch may be bad my lights went i replaced the switch and they worked again i even got pulled over for not having running lights.
saleen9899
  • Nov 21, 2006
i replaced the switch 3 times...no luck, the problem is somewhere else...
Adam95GT
2,564
Burlington, NJ
Nov 21, 2006
  • Nov 21, 2006
did you check the dimmer... if they are unplugged i know the lights wont light up... needs to complete the circuit... i know it was that way on my probe atleast
saleen9899
  • Nov 21, 2006
dimmer?
are you talking about the part of the switch that rotates?
Adam95GT
2,564
Burlington, NJ
Nov 21, 2006
  • Nov 21, 2006
saleen9899 said:
dimmer?
yea... on probes it was seprate though... check the wires to there... there is something out of the loop... but you said you replaced the switch several times... so ya...
HISSIN50
34
129
Nov 21, 2006
#10
  • Nov 21, 2006
  • #10
For the original issue, had you checked the dimmer fuse (13 IIRC)?
Good luck.
Adam95GT
2,564
Burlington, NJ
Nov 21, 2006
#11
  • Nov 21, 2006
  • #11
Good luck.
thats what i was thinking but he said he checked the fuses...
HISSIN50
34
129
Nov 21, 2006
#12
  • Nov 21, 2006
  • #12
Adam, I hear ya. But after a course of events like occurred, it never hurts to ask (just in case someone doesn't know that the dimmer has it's own fuse).
If the dimmer fuse is ok, I'd check for dimmer circuit output at the headlight switch.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
M
67 Mustang Ignition Switch Wiring Diagram needed
  • Michaelell
  • Sep 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 3, 2026
Michaelell
M
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
