  • SN95 4.6L Mustang Tech
NEED HELP, after plenum install
  • Thread starter Thread starter 4.6 Rocket
  • Start date Start date Jan 28, 2004
4.6 Rocket
85
Thousand Oaks, California
Jan 28, 2004
  • Jan 28, 2004
I just got done installing my accufab plenum with the accufab 70mm throttle body. Everything went smooth and I double checked all the connections. When I started the car it seemed a little upset with me but after 5 min it settled down. I took it for a drive and if I pull a gear up to 3000rpm (for example) and I let off, the car holds itself at 3000rpm and very slowly goes down. IS THIS NORMAL? Also when I come to a stop the car is idleing at 1100 instead of 800 before. Can you guys help me out.
Thanks.
W
wht99gtconv
267
  • Jan 28, 2004
Thanks.
I installed the Accufab plenum on mine and it does the same thing.
4.6 Rocket
85
Jan 28, 2004
  • Jan 28, 2004
How long have you had yours installed for. If it has been a while, have you noticed problems while driving and how was the performance increase?
Y
Y2K_MustangVert
185
  • Jan 28, 2004
Check your throttle linkage cable. It might be catching the vacuum hose that comes out of the back of the plenum. I have a C&L plenum, and if I had not noticed this, then I would have had the same problem that you are having. To fix the problem use some washers(to act as spacers) under the linkage bracket that connects to the plenum. This should fix your problem!!
Bulldog6Z6
163
Houston Texas
Jan 28, 2004
  • Jan 28, 2004
does it stop at 1500 rpms?
4.6 Rocket
85
Jan 28, 2004
  • Jan 28, 2004
No why, it idles at 1100. What would 1500 mean?
Bulldog6Z6
163
Houston Texas
Jan 28, 2004
  • Jan 28, 2004
I did it and mine kinna hangs at 1500 rpms then drops to the idle speed
StangLou
1,264
Holly Springs, NC
Jan 28, 2004
  • Jan 28, 2004
Id check what Y2K said, the throttle cable could be caught on something. I know some people complain about the time it takes some of the 99+ cars to rev down, but Ive never had a problem with mine. It does sound like the throttle cable could be getting snagged since it revs down very slowly and is idling higher. Let us know what you find out, and what you think about it performance wise. Im thinking of purchasing the same setup later
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 28, 2004
  • Jan 28, 2004
leaky gasket? something to do with TH position senser?
Bulldog6Z6
163
Houston Texas
Jan 28, 2004
#10
  • Jan 28, 2004
  • #10
ya I think my problem is with the tps sensor im gonna order a new one
downsouthman1
643
Texas
Jan 28, 2004
#11
  • Jan 28, 2004
  • #11
Read the following thread I posted: http://forums.stangnet.com/showthread.php?t=417403
D
dlsdj
121
Corpus Christi, TX
Jan 28, 2004
#12
  • Jan 28, 2004
  • #12
Throttle Body
Guys, if you have a late model GT then there are 3 things you have to do so the idle will be correct.
1. Diconnect the battery
2. If the new TB has an idle adjustment screw it has to be closed. Late model stangs stock TB do not have any idle adjustment screw just a pluged hole.
3. Set the TPS to .98 with a meter.
After this is done the car should settle down and within a few days run just fine.
downsouthman1
643
Texas
Jan 28, 2004
#13
  • Jan 28, 2004
  • #13
I didn't have to do any of that w/ the Accufab 75mm TB. Just make sure the rear plenum vacuum hose is clear of both Throttle Cable lines.
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
