Need Help Asap!
Hey guys, I tried to start the stang this morning and I heard an electrical spark and the car wouldn't start so I popped the hood and my ground wire (running from my positive battery cable) had melted to my battery and was smoking, I touched the wire and it was VERY hot. So I put electrical tape around it (with all intentions of replacing the wire afterwards) and it hesitated to start, I pumped the gas pedal once and it finally started. All the sudden my low coolant light came on so I checked my coolant and it was just fine. So I turn off the car and wait about a minute, go out and attempt to start it again and then nothing, all of my lights, my fuel pump and everything were working and the ground wire got hot again, the engine didn't even attempt to turn over. Please help me out, I have school on Monday and I need to know what I need to do to fix this as soon as possible.
Possible failure items:
1.) Short in power feed wire from starter solenoid by battery to starter. Look for bare spots in the insulation where it may have melted or rubbed and shorted to the chassis or engine.
2.) Bad connections (disconnect & clean)
3.) Corrosion inside battery cables. Look for swelling or bulges in the cable. The cable will look like a snake that swallowed a mouse.
4.) Failed starter. Pull starter and take it to the auto parts store & have them test it.
[:D] YAAY it was the ground. The spot that had melted through was right next to a wire connector, where it looked like the previous owner had extended the ground for some reason. So I snipped the ground back to the original wire, reconnected it and it started right up. The low coolant light went off to, she's runnin great now.
