  • 1994 - 1995 Specific Tech
Need help ASAP!!!!!
  • Thread starter Thread starter Venom351R
  • Start date Start date Jul 9, 2008
Venom351R
4,548
41
98
MAINE
Jul 9, 2008
  • Jul 9, 2008
As some of you know I'm having some work done on my motor. Ran into a problem today that the 302 fuel rail will not fit on the Trick Flow R 351W lower. Needless to say I'm in need for a new fuel rail I'm trying to avoid spending the $500+ for the Aeromotive or Trick Flow Kits, its just not on the budget.
I did find a fuel rail kit that's for sale for a 351W in the add it says
"Item for sale is a fuel rail set for a 79-93 mustang with a 351w swap"
What I would like to know is will this fit on my 95 351W? I assume that it does not matter what year the 351w swap is going into, a 351W is a 351W either way regardless of its going in a 93 or a 95???
earleys94gt
1,223
Ashley, Ohio
Jul 9, 2008
  • Jul 9, 2008
I would imagine the style or type of manifold would matter more the what year the 351W was going in.
Unless the 79-93 Foxes have some special ''hook ups'' for a 351W in that body style, I'd say your good the item in the ad.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jul 9, 2008
  • Jul 9, 2008
From what others here have said, the 302 fuel rails will fit but you'll have to replace the rubber hoses with longer ones.
Venom351R
4,548
41
98
MAINE
Jul 9, 2008
  • Jul 9, 2008
Do you mean the hose that goes in the front that connects the two rails? This is the area that the problem is coming from. This front connection is not long enough and its causing the fuel rails to be spread apart and not allowing the injectors to seat properly
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jul 9, 2008
  • Jul 9, 2008
Exactly. I haven't done this myself, just gleaned the knowledge from other 351 buildup threads. *looks* Found the thread! http://forums.stangnet.com/7063151-post11.html
Venom351R
4,548
41
98
MAINE
Jul 9, 2008
  • Jul 9, 2008
Awesome thanks
It would be so good to use the stock rail. I PM'ed a few guys in that thread to find out where they got the hose they used to get it to work. I was looking at the PP fuel rails but after reading how much of piece of trash they are I'm not going to, I suspected that anyway.
Zero_chance
1,244
Maricopa, AZ
Jul 9, 2008
  • Jul 9, 2008
I believe Pokageeks pain thread has a few people that chimed in on how they were able to modify the stock rails to go on a 351W. Pics included if I remember correctly.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jul 9, 2008
  • Jul 9, 2008
when i did my 351 swap in my fox i cut the rubber divider line out and spliced in a 8" piece of braided line and put two clamps on each end to make sure nothing would slip. works great.
str8stang036
1,382
Miami
Jul 9, 2008
  • Jul 9, 2008
how much power are you wanting to make with 351w? If 500+ the go with upgraded rails.
Venom351R
4,548
41
98
MAINE
Jul 10, 2008
#10
  • Jul 10, 2008
  • #10
That's a great suggestion to, thanks.
I'm not making that kind of power right now that will need a fuel rail upgrade kit. It is something I would like to to regardless but not right now considering the cost of the kits b/c Ive already spent a lot on this build up.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
1994 - 1995 Specific Tech May 29, 2025
General karthief
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
