need help bad!!!!!!!!!!
BDASPNY
103
HAMPTON ROADS
my car stranded me, hopefully you guys can help. i started my car and it sounded like the starter stayed engaged but did not grind. the engine would stay running but at a higher rpm. i could shut off the engine but the starter would keep going. all the belt driven stuff kept going. all i could do was disconnect the battery. i have no clue as to what has happened! please help!........:nonono: :shrug:
That EXACT thing happened to me....now I have an odd (annoying) clickie, grinding noise every time I start the car. The noise it makes is quite hard to describe but it is annoying. While the car was still running with the key off it made a lot of smoke and an awefull burning smell. I changed out the starter and the solenoid. The car still makes the sound, my car stunk like burning electrical for 2 weeks and I am hoping when I swap the motor out it takes care of the noise. The car has not had the original problem since.
I am not sure what caused this but my buddy told me it might have been the starter solenoid that might have been the culprit. Who knows, but I hope someone can shed some light on the problem. Good luck!
The solenoid is a place to look. Otherwise (if the solenoid is not latching and providing power to the starter after you release the key), the bendix might simply be hanging up.
If it's the solenoid, you can do some roadside fixing. Or compression start the car so the starter never engages.
Good luck.
i'll check the solenoid. cheap enough part prob just pick one up. i just never even heard of such a thing happening. it was odd to see the entire acc belt and all going w/ the engine off and really loud. any other suggestions?
So you're saying the starter is actually engaged? Even with the key off? That's definately something either jacked up with the solinoid or your ignition in the column. When you disconnect the battery, everything obviously goes off, but does it automatically start turning over when you hook the battery back up? Or does it take ingaging of the ignition/key to make it stick?
when i hook the battery back it starts turnign over again. just like before when i turned it off. i don't need to turn the key again. the starter never made any grinding noise when the engine was actually running.
first i want to thank you guys for your help. i changed the solenoid and it worked perfectly. so hopefully that was the only prob. when my mechanic comes back from vacation i'll have him check it out. i'm just glad i got it back home. leaving it in the walmart parking lot made me really nervous, as with most of us i have put so much time and effort in this car don't want some idiot stealing or messing it up.
Yep the starter relay on the fender is stuck on, or the ignition switch is not going all the way back to run, keeping power to the starter relay.
If replacing the relay fixes it you should be good. If not, check the ignition switch.
I also had the same problem but I didn't have the tools on hand to disconnect the battery. I pulled the ignition wire from the soleniod and it kept trying to turn over. Therefore, I think my problem was the soleniod and not the ignition switch b/c I cut of the link between the two and kept having the same problem. Since I couldn't disconnect the battery I just inserted the key and tried to start the car as it was already trying to start itself. It fired right up and I haven't had a problem since........the weird thing is my soleniod is 3 months old.
