  • SVT Tech Forum
Need Help Diagnosing T Rex Fuel Pump Power Issue
  • Thread starter Thread starter RobIAm
  • Start date Start date Apr 24, 2015
R
RobIAm
  • Apr 24, 2015
I have a 96 Cobra with a Vortech SQ supercharger. After changing an idler pulley this week I went to start it up and the inline T Rex pump didn't work. I checked the relay (in the trunk) and it tested fine. I connected the power supply from the under dash fuse box directly to the fuel pump supply bypassing the relay and the pump started working. I then checked the yellow wire that connects the relay low side power to the cars cars fuel system and I dont see any voltage when the key is turned on. I tested the inertia switch and it has continuity. I'm no electrical diagnostic person does anyone have advice on what the most likely culprit is from here? Thanks!
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2026
Mhaley2006
M
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
D
89 foxbody fuel pump not priming
  • Dubsantana
  • Jul 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
AeroCoupe
  • SVT Tech Forum
