  • SN95 4.6L Mustang Tech
Need Help Fast Guys !!!!!!!!!!
  • Thread starter Thread starter stangman
  • Start date Start date Feb 1, 2004
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 1, 2004
  • Feb 1, 2004
me & a friend (boss281) are "trying" to lower my car. this is turning into a friggin nightmare. ok we finally got one side on the front done & moved to the back on the same side. well we finally got the rear spring in after quite a while of beating the crap out of it, cause we dont have a spring compressor & its to late to get one at any auto parts store.
well the problem is we can't get the axle & the lower control arm to line up the holes are about a inch apart & will not line up at all is there anything we can try to get them to line up at all thanks for any help
Boss281Mustang
17
Huntington, WV
Feb 1, 2004
  • Feb 1, 2004
*Bizump* Cmon fellas
JonJon
4,801
back in Marylands
Feb 1, 2004
  • Feb 1, 2004
What my friend and I did when we changed my LCA's, we put the jack under the LCA, jacked it up as far as it would go, and jumped into the trunk.
The 2nd side we didn't have to jump into the trunk, it lined up fine.
LI98GTStang
1,715
L.I., NY
Feb 1, 2004
  • Feb 1, 2004
Hey there is a good superbowl on. I did the rear - both sides then went to the front. Never heard of doing one side then the other. I think that is your problem because the rear is rotating on you.
I would start with putting the rear of the car (both sides) up on jack stands. Then place the hydralic jack under the rear differential and adjust it so that you can line the bolt to get it through. You also might need an adjustable jack under the lca so that you can move that too. Takes some wiggling, but you will get it.
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 1, 2004
  • Feb 1, 2004
how on earth would the rear rotate on the car we did the front right first & then decided to do the rear cause we wern't sure we put the right spring in, cause it only lowered the car about 1/4 of an inch (i hope it settles & gets lower or i'm going to be really pissed )
well i'll post a pic so you all can get a little better idea of what we are talking about
JonJon
4,801
back in Marylands
Feb 1, 2004
  • Feb 1, 2004
I had that same problem. We just played with it and eventually we got it in. We had to jack up the LCA, then lowered it, then jacked the other side, then lowered it, eventually it went back in.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
