Need help finding wiring gremlin
  • Thread starter Thread starter Kurt
  • Start date Start date Jan 26, 2004
K
Kurt
149
South Hill ,Va
Jan 26, 2004
  • Jan 26, 2004
putting in new parts now i have no power , replaced burnt fuse, new battery, solinoid, voltage regulator, pertronix electric ignition, headers.
worked fine after i put in pertronix, then pulled apart to put on headers, battery had a crack next to post so i replaced it, car runs, i have the coli on its own wiring, fuse and toggle switch, so i jumped the solinoid and she runs, but no juice to ignition, lights etc. so i replaced the voltage regulator since i had not replaced that before. but i still have no juice, please help.
ps. the reason i have the coil on its own system is because the fuse for the coil on the fuse panel is missing the metal clip if you know where to get fuse panel or parts for them let me know
thanks,
Kurt
M
mtpony
357
flower mound Texas
Jan 26, 2004
  • Jan 26, 2004
usually with selinoid and battery more juice is getting around. check ground wires and wires to starter on engine. possibly the extra juice caused a corroding cable to break and or get worse.
happened to my 71. new selinoid broke starter cable, new cable broke starter, now everything is doing okay.
mike
K
Kurt
149
South Hill ,Va
Jan 27, 2004
  • Jan 27, 2004
so soes anyone know where to get replacment fuse paneles or fuse panel parts.
Kurt
bud4660
459
Mesquite, Tx
Jan 27, 2004
  • Jan 27, 2004
I will take a shot at it. Did you check the fuseable link wires that are hooked on to the solenoid. They are there to protect the wiring in the car. If you have a short they burn out. I know if you try and jump start the car and touch the cables wrong they blow.....
The fuse panel comes with the main dash wiring harness I believe. Most of the classic mustang parts places have them. Not cheap.
Also check the wires from the alternator over to the starter solenoid too. I think there is a fuseable link in those too??
G
GaPonyFarm
663
Columbus, GA
Jan 27, 2004
  • Jan 27, 2004
Kurt
Radio Shack catalog has a few different models... I'd look at the painless wiring stuff also...very good quality.
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 13, 2025
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
