  • SN95 4.6L Mustang Tech
Need help here- new gear- leaking
  • Thread starter Thread starter trickyshadow
  • Start date Start date Nov 7, 2005
T
trickyshadow
22
  • Nov 7, 2005
Need help here Just put a 4.10 gear in and the pinion seal was leaking. Put new seal in and it is still leaking, any ideas on how to correct this problem
Give Me TP
936
Republic of Texas
Nov 7, 2005
  • Nov 7, 2005
was the pinion bearing seated properly?
T
trickyshadow
22
  • Nov 7, 2005
yes we double checked everything, appears to be leaking from the bottom of the seal.
Give Me TP
936
Republic of Texas
Nov 7, 2005
  • Nov 7, 2005
Try a thin film of RTV around the metal rim of the seal when you drive it in, or if it's leaking at the rubber lip, check the pinion flange for burrs or a groove. Also make sure the breather hole in the axle housing isn't stopped up.
T
trickyshadow
22
  • Nov 7, 2005
why did'nt I think of that, thanks for the tip....
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
