need help no fuel ?????? wont start
mr-mike
122
had to put up my 99 gt for 5 months , went to start it , no fuel in rails ? reset trunk switch , still no fuel ? are there any fuses ? had sta-bil in the gas she spins but seems like the pump is not comming on I cant hear anything ...... any ideas or help greatly needed.....thanks guys.................................tank is full
got it running
all fuses were ok , found the fuel relay & tapped it with a screw driver & sure enough it fired over ? I guess the connections are dirty , what is needed too remove the iner fender well ? maybe I should just change out the the relay switch as I have 150, 000 + miles ....... leaving cars outside covered or not never works the elements just cause stuff to oxide or rust or dry rot or whatevr ...thanks guys its raining cold & was in bad spot , now I moved it to a better spot .....10-4
Replacing your fuel pump relay module!
If your GT Mustang has the Constant Control Fuel Pump Module located between the passenger side fender and fender well, and you are thinking of replacing it, here is what I would do. To take the easy way out, I would cut out a portion of the fender well big enough to remove the Fuel Pump Module. I said Fender Well, Not the Fender! You can do this by using a dremmel tool with a grinding wheel attachment. This is an awesome tool, let me tell you. I have used it to do this type of cutting on many projects. It will cut into the sheet metal very easily. You just have to make sure you purchase a good amount of the grinding disk wheels. They come in a small plastic container. They are about 3/4" in diameter and about 1/16" in thickness. You would need to jack the passenger side of your car up and place a jack stand in the appropriate location, that is if that is the side of your car where the fuel pump module is located. Remove the tire which should give you more than enough room to work. Once you have chosen and marked the location that you will be cutting off, and then made your cut. You can then install the clip on nuts, shown in the picture below on the edges of the remaining fender well, that you removed the cut out section from. These clip on nuts are sold at hardware stores or auto part stores. Then simply install a new slightly larger piece of sheet metal that will overlap the existing cut in the fender well. The overlap can be as little as 1/2". You have to make sure that the new cover piece conforms to the shape of the area that you cut off. So, the sheet metal screws will run through the new sheet metal cover, and then screw into the clip on nuts. Of course you have to drill the appropriate size holes in both the new sheet metal cover, and the existing fender well cut. You can do this by drilling all the necessary holes in chosen locations on the new sheet metal cover, then place the cover over the area that it will be covering, and mark the holes that you will be drilling in the cut off section of the fender well, and drill out those holes. Then install the clip on nuts. Simply apply some type of silicone between the new cover and the existing cut before you install it back in place. Believe me this is alot easier than trying to re-move the fender to get at the fuel pump module. Besides that, if you have related fuel problems in the future, and need to get at the fuel pump module, it will be a piece of cake! Good luck, Tommy.
thanks Tommy
sounds like a plan as that inner fender looks like a pain to remove & looks like a dumb place to get at ....... I like your idea as who knows if you need to get at again ....... if I didnt read up online I wouldnt even know it existed or where it was , I was thinking fuel pump ....... I lost the owners manual so I checked all the fuses & they looked OK ..... my cruise control went out years ago I wrote in and one guy a nice guy wrote look for a hook that attaches to the brake petal & see if its off ....sure enough it was as I was under there a week before & must have done it so its nice when someone like yourself takes the time to be helpfull ....thanks again & have a good day ...............................
Yes, I was reading some of the treads concerning the passenger fender removal. Sounds like it is a real pain in the butt! Far too many things to contend with. Ford always thinks of ways for the customers to bring the car back to them to get their money back. This is just one of many obstacles that exist for allot of items. Another one is for the fuel pump removal. All they had to do was design a removal patch in the trunk of the car. I think some of the later models now have the patch in the trunk for the fuel pump removal, not sure? If you, or anyone else decides to make the cover for access to the Constant Control Relay Module, you will be glad you did! Glad to be of some help. Good luck, Tommy.
hiding parts ?
ford , chevy & all the others hid parts for years , the japs did leave some spots in the trunks to get at the fuel pumps but the front wheel drives a big V6 in there side ways is as dumb as dumb can get , I will never own a front wheel drive ...good in the snow or not ....... I have had plenty of V8 fords & the 289-302-351 if taken care of can go way over 200,000 miles , plenty of parts not that hard to work on & I always liked them ......... once in a while things happen ...now there all in trouble & they may all go down .....the China boys say they can make a car & sell it brand new for $7,000 they can flood the earth with them ! not a happy thought ...... who knows what the future will be like in 10 years ? anyway thanks again for the help , hang in there & enjoy everyday .......... :nice:
