B BOWTIEKILLR New Member Nov 26, 2005 100 0 0 Feb 20, 2006 #1 Feb 20, 2006 #1 how do you de-pressurize the fuel system to do fuel injectors?
S skip nay New Member Apr 15, 2005 110 0 0 Chambersburg Pa Feb 20, 2006 #2 Feb 20, 2006 #2 BOWTIEKILLR said: how do you de-pressurize the fuel system to do fuel injectors? Click to expand... There should be a shrader valve to push down or you could disconnect the fuel pump and coil and try to start it. Either way should help
Beasly B New Member Jan 7, 2006 165 0 0 Virginia Feb 20, 2006 #3 Feb 20, 2006 #3 on the fuel rail near the front of the motor there is a schrader valve which looks alot like a valve stem on a wheel , just remove the black cap,and push in on the core and it will bleed it off.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Feb 20, 2006 #4 Feb 20, 2006 #4 Put a drain line or at least a rag over the Schraeder valve, or the fuel can spray all over. Good luck.
04sleeper Founding Member Jun 22, 2002 2,674 14 89 Dallas, TX Feb 20, 2006 #5 Feb 20, 2006 #5 I always put a big towel around the spring clips when I slowly pull them off. Remember to use EYE PROTECTION.
B BOWTIEKILLR New Member Nov 26, 2005 100 0 0 Feb 20, 2006 #6 Feb 20, 2006 #6 haha thanks guys. i was gonna try to do it tonight, but i decided to hold off till tomorrow. daylight works much better
