Need help, problem installing headers
  • Thread starter Thread starter tddpop
  • Start date Start date Dec 11, 2005
T
tddpop
26
Salt Lake City, Utah
Dec 11, 2005
  • Dec 11, 2005
Right now I am trying to install some Bassani equal-length headers on my 90 Notchback. Because they are equal lengths the motor needs to be lifted a few inches to get the passenger side header in.
I have unbolted the motor mounts from the k-member, unbolted the tranny from it's mount, but when I try to jack up the engine it still jacks the whole car up, and the motor doesn't move any, giving me no more clearance. Is there anything else that needs to be unbolted so that I can lift the motor a couple of inches to get the header in?
Thanks everyone.
carbed87
215
  • Dec 11, 2005
id check all the random ground straps and what not.
oh you know what... unbolt the fanshroud, i know that hung $hit up when i was doing motor mounts.
ill post back upp if i think of anything good.
T
tddpop
26
Dec 11, 2005
  • Dec 11, 2005
The ground straps I hadn't thought of, I'll check that. There is no fan shroud anymore, it has a elctric fan conversion. Thanks.
Bladez5_0
460
Goose Creek, SC
Dec 11, 2005
  • Dec 11, 2005
If your motor mounts were like mine then the studs on them go through the k member. You may have to unbolt the mounts from the motor itself.
M
mustangmarks
102
  • Dec 12, 2005
Try jacking it up til the car starts going up then try shaking the car around alittle and see if it breaks out. This is what i did also make sure your jacking evenly you dont want to start cocking the motor. Hope this helps
shttygtstang
978
  • Dec 12, 2005
wow not good advice.... ever seen a jack fly out from under a car. I woulkdnt do that. een if ya jack it up alittle I almost had a car fall on me while dropin my AOD.
if possible start the motor put it in first gear. while 1 mount is unbolted and it should tq. up in the air a little . It will allow you to free up what ever was biding up
M
mustangmarks
102
  • Dec 17, 2005
I'm not saying jack it up all the way just enough till the body starts coming up then carefully move the body back and forth I can'tee any harm in that just be caution and don't be underneith it when your doing it.
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
