Need help quick!!! Car won't start!!
  • Thread starter Thread starter Dtowncats
  • Start date Start date Sep 28, 2004
D
Dtowncats
340
York, PA
Sep 28, 2004
  • Sep 28, 2004
I have a 92 Gt stock except cat back exhaust. I just got my tranny rebuilt about a month ago so I took my car off the road while this was getting done. This morning I put insurance back on it and picked it up from where it was sitting( at my grandmothers house). It started right up. Went to the gas station and put about a half a tank in. Then I went home and installed new lx tail lights that I just bought. I was getting ready to go to my girlfriend's house and got in and tried to start it up. It turned over and actually started but it keeps shutting off right after that point. The battery is fully charged. I have no clue as i'm not an expert on cars! I need your help quick! Thanks.
stang976
853
Westchester, NY
Sep 28, 2004
  • Sep 28, 2004
will it stay started if you hold the gas down after start up?
D
Dtowncats
340
York, PA
Sep 28, 2004
  • Sep 28, 2004
no it just sputters
D
Dtowncats
340
York, PA
Sep 28, 2004
  • Sep 28, 2004
Ok well my uncle told me i probably bumped the inertia switch in the back while switching my tail lights.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Sep 28, 2004
  • Sep 28, 2004
yup that could definately be a problem
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2004
  • Sep 28, 2004
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
D
Dtowncats
340
York, PA
Sep 28, 2004
  • Sep 28, 2004
It was the inertia switch!! I am so relieved!! Thanks anyway everyone!
blkstangman88
646
  • Sep 29, 2004
just a thought, under the drivers seat in my 88 gt is a plug that goes to i dong know what but when it cam eupplugged it was like the inertia switch was hit also, just keep that in mind next time.
HISSIN50
34
129
Sep 29, 2004
  • Sep 29, 2004
that would be the FP relay. the positive key-on pulse comes through the inertia switch to the positive coil on the relay.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
J
Car won’t start
  • JLB
  • Nov 15, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
