Need help quick! Rear Lower Control Arm.
  • Thread starter Thread starter caine0
  • Start date Start date Jun 27, 2005
C
caine0
121
Jun 27, 2005
  • Jun 27, 2005
I'm in the middle of switching my springs, so I decided to do the lower control arms at the same time. The uppers looked tough to get too, but I figured I wouldn't have a problem with the lowers... well I am!
I am having problems getting the bolt out of the lower control arm to frame connection. I got the nut off no problem, then tried hammering out the bolt from where the nut was, but it won't budge. I can't get a wrench into the hole where the bolt is because my muffler is only about an inch or so away from it. I would take off my muffler, but my entire exhaust system is all welded. I also tried putting pliers on the end that the nut was and tried to turn the bolt from that side, but there's not enough room to move the pliers and I can't get a good enough grip. Do I need to line up the control arm in some way so that I can hammer it out like I was trying before?
So what do you guys do when you switch lower control arms? Any tricks? Is it impossible to do without taking the muffler off? Thanks, I need to finish this tonight.
CManT1914
3,172
Killeen, Texas
Jun 27, 2005
  • Jun 27, 2005
Try putting a jack underneath the actual control arm and lifting it a little bit. If the rear is dropped completely, then there might be to much tension on that bolt. Then, get a BFH and pound it till it comes.
J
JerryDaugherty
309
Near Dallas
Jun 27, 2005
  • Jun 27, 2005
Yea you need to either jack the control arm or the rear up it will relieve the tension. then just wriggle the control arm around while you hold the bolt. you will feel when there is some slack then just bang it out.
C
caine0
121
Jun 27, 2005
  • Jun 27, 2005
Thanks guys, I'll give it a shot.
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
