  • SN95 4.6L Mustang Tech
need help quick!! starter bolt
  • Thread starter Thread starter notoriouspig
  • Start date Start date Nov 17, 2008
N
notoriouspig
172
FL
Nov 17, 2008
  • Nov 17, 2008
What is the exact combination of socket extensions or what ever to get the top starter bolt....been working at it for 3 hrs....
mogs01gt
3,113
30
119
Ohio
Nov 17, 2008
  • Nov 17, 2008
3 feet and an swivel at the end. Go through the engine mount on the K member.
N
notoriouspig
172
FL
Nov 17, 2008
  • Nov 17, 2008
that is one of the ways we were trying... just could not quite get the socket to sit on the nut flush.. did you have the swivel directly connected to the socket..
0302Cobra
San Antonio, TX
Nov 17, 2008
  • Nov 17, 2008
I had this same exact problem. The answer above will work. As far as I could tell there is only one way through. I played with it until I got the extension right next to the bolt then attached the socket. Once I knew "the way" I did not have to do this again and was able to pass it through with the socket attached. I just took out my transmission so I feel your pain. See the TCI post below. If it does not go right up to it, go out and back in at a slightly different spot. I do not have my car here or I would go out and take a pic for you. Hope you get it.
N
notoriouspig
172
FL
Nov 17, 2008
  • Nov 17, 2008
finally got the bolt out...what a pain...i finally used a small ratchet with a small head and was able to position it just right...got all the bolts out or loose... see how it goes in the morning dropping it down...
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
