9 97saleen13 New Member Sep 25, 2005 27 0 1 tonganoxie ks Oct 30, 2005 #1 Oct 30, 2005 #1 i need the torque specs for the 4.6 intake manifold thanks eddie
bryan0 New Member Jun 9, 2005 175 0 0 Bethel, CT Oct 30, 2005 #2 Oct 30, 2005 #2 97saleen13 said: i need the torque specs for the 4.6 intake manifold thanks eddie Click to expand... This is from the Hayne's Repair Manual. 4.6 SOHC Intake manifold to cylinder head bolts: 15-22 ft/lbs then retorque when engine is hot. 4.6 DOHC Intake/side plates assembly to cylinder head: 15-22ft/lbs, tighten another 90degrees. Hope that's what you were looking for. Good Luck.
