Need help replacing window crack parts...details inside:
85_SS_302_Coupe
6,945
1,598
223
Northern KY
OK i'm talking about the part that the window crank attaches/screws onto. The screw that holds the crank on has broke off, and trying to drill the screw out has only created more problems, so i wanna replace the spline part that the crank slips over.
Questions are, can i, how do i, and where do i get the part?
I haven't looked at one in several years, but I know you can drill out the 3 rivets and replace the complete regulator with one from another car. I don't know if the splined part itself can be replaced or not.
Good luck!
Ditto that, take your cordless drill to a junk yard and pop one out of another stang. Sometimes you luck out and can pop the rivets off with a chisel and hammer. Just use bolts and locknuts to put it in your car.
Jamie
