Need help tapping oil pan
  • Thread starter Thread starter oray777
  • Start date Start date Dec 21, 2006
O
oray777
Northern California
Dec 21, 2006
  • Dec 21, 2006
I've got a general idea on how to do it but can anyone give me more specifics on what size tap, how far to tap, etc. Thanks.
O
oray777
Northern California
Dec 21, 2006
  • Dec 21, 2006
Just wanted to add also what size punch.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Dec 22, 2006
  • Dec 22, 2006
I assume u are tapping for a blower oil return line
Here is the advice I can give you.
1) Take your time
2) cover the tap with lots of grease to catch as much metal shaving as possible
3) drain oil AFTER tapping... and replug the oil pan with magnetic plugs just for safe measure.
F
fastranger347
59
york PA.
Dec 22, 2006
  • Dec 22, 2006
i know a lot of people puch and tap but that always scares me, the only truly safe way of doing it is to pull the pan and drill a hole and weld a fitting on the side of the pan, aht way you are sure there are no filings migrating they're way to your oil pump
speedytang
765
Marengo,Ohio,US
Dec 23, 2006
  • Dec 23, 2006
People been punching the pan for a return line for 20 years now on a 5.0 and never have heard of a problem and since the motor needs to come out to remove the pan a punch is easy.
poneypower89
Dec 6, 2004
Dec 23, 2006
  • Dec 23, 2006
I tapped the oil pan in my car. Before I did, I was pretty much scared sensless by the bullcrap that speads over these forums by in or UN experienced posters. I bet 90% of the people against tapping oil pans (because it will damage the motor ) have never actually tried to do it. When actually came time to tap the pan, it turned out to be the EASIEST step in my entire blower install. go figure uh
the metal shaving from a pan tap are so minimal its nearly impossible for them to do serious harm. Albiet, anything can still happen so don't completely slack on the saftey/precuation perspective.
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
New to this
  • 5.ohCS
  • Nov 1, 2026
2005 - 2014 S-197 Mustang -General/Talk- Nov 1, 2026
5.ohCS
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
