Need Help With 2003 Mach1 Alternator Replacement
The Ford service manual does state to "relieve the accessory drive belt" first. Remove the belt from the alternator pulley but leave the drive belt in place.
Next two steps are to remove the (6) bolts and lift up.
No where is there any mention of the coolant crossover.
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
Thanks. Tried and tried and ended up taking off coolant crossover pipe.
